Thread: Brake bleed
Created on: 08/01/15 12:36 PM
ryancoke
ryancoke's Gravatar
Brake bleed
08/01/15 12:36 PM
Just bleeding my brakes guys and wondering what would be causing this. I bled the master cylinder. No air bubbles. Then went to the right caliper (from a sitting on the bike point of view) and bled that brake. No air bubbles. Then the left brake and getting ever so tiny bubbles in the line. I am using a pneumatic system to bleed. Tried resetting the line on the bleed nipple numerous times and still tiny bubbles. It feel like I get good brake pressure on the brake lever. Can't see any leaks anywhere. Is this normal to get the tiniest of bubbles? Thx!
RE: Brake bleed
08/01/15 1:45 PM
Possible a too far open nipple, the pneumatic system might be sucking air thru the threads, and this is where you see the bubbles appear?
ryancoke
ryancoke's Gravatar
RE: Brake bleed
08/01/15 2:26 PM
Thx hub will look into that
RE: Brake bleed
08/01/15 3:49 PM
Hub is correct.
OldMan
OldMan's Gravatar
San Jose, Sunny California
RE: Brake bleed
08/04/15 4:29 PM
Is it OK to put little grease around the thread when bleeding brake? Grease prevents air sucked through the thread or will grease contaminate the line?
1973 Suzuki GT250, 1976 Kawasaki KH500A8, 1979 Yamaha RD350, 1985 Yamaha Maxim700X, 1987 Kawasaki EX500, 1994 Honda CBR600F2, 2004 BMW R1100S, 2005 Kawasaki Z750S, 2003 Suzuki SV1000N
RE: Brake bleed
08/04/15 4:59 PM
you should only be using minimal pressure to bleed, I typically don't exceed 3 inches hg. This allows the brake fluid to form a seal in the threads. If you use too much vacuum, you'll pull air through the threads like Hub's saying.
RE: Brake bleed
08/04/15 5:43 PM
Good question... No, not good. Think... 'for every action;' here comes contamination.
Purge is fluid behind the last thread at the bottom of the nipple. So just close the nipple as you keep moving the lever to the grip. Air happens way up and around the threads you see the mix of both.
RE: Brake bleed
08/04/15 8:02 PM
I always get tiny bubbles even after the system is totally bled. It's just air from OUTSIDE getting sucked past the threads and and going right back out the nipple. No problem as long as the brake feels good and firm.
